Fixture Groups
Using Fixture Groups​
You can create groups of fixtures or dimmer channels, which can then be quickly selected together by pressing a single button or typing the group number. You can, for example, make a group for each type of fixture, then also group by stage left / stage right, etc.
If you have a lot of fixtures, clever use of groups will greatly increase your programming speed.
Groups Window
Groups can be stored in the Groups window, on fader handles or on Macro/Executor buttons.
If you assign a group to a handle with a fader, the fader becomes an intensity master for the group. You can also set different functions for the buttons using Key Profiles.
Record a Group​
Recording Groups
If the Groups window is not visible, you can show it by pressing Open/View, Group (above numeric keys).
  1. Select the fixtures/dimmers you want in the group (the order in which you select them will also be stored in the group).
  2. Press Group (top right of the numeric keys) then Record Group. You can also press Record then Group.
  3. Use softkey A to enter a number for the group, or B Provide a legend to set a legend.
  4. Touch an empty button in the Groups window, or press the Select button of a fader handle where you want to store the group, or press Store to store as a numbered group.
  5. Press Clear then repeat from 1 to store other groups.
  • You can also press Avo and Group to go directly to the Record Group menu, or on the screen touch the button twice to use Quick Record - on the first touch the button will turn red with a +, on the second touch the group will be recorded.
Quick Record
  • To select all the fixtures/dimmers in a group, just press the button for the group.
  • The order in which you originally selected the fixtures when creating the group is also stored. This takes effect when you use the last fixture - next fixture functions described in the next section, and when you use Shapes, Fan mode and Fixture Overlap functions. You can change this later, see the next section.
    You can override the selection order while recalling a group by holding down the group button and using the softkey options.
  • You can also recall a group by its number:
  1. Press Group.
  2. Type in the number of the group you want to recall.
  3. Press Recall Group.
  • The Group button also gives you facilities on the softkeys to edit and delete groups.
  • You can use Select If to deselect a group of fixtures from a selection. This can be useful to select a subset of fixtures from a group. For example if you have a group for the outside edges of a 5x5 matrix, and a group which selects odd and even pixels from the matrix, you can select the outside edge, then use Select If with the odd/even group to remove the alternate pixels round the edge.
Deleting Fixtures from Groups​
To remove fixtures from a group:
  1. Press Group.
  2. Press the button for the group you want to change. All fixtures currently in the group will be selected.
  3. Deselect the fixtures you want to remove from the group.
  4. Press Exit.
The group will now only contain the fixtures which remained selected.
Auto Groups​
When patching multiple fixtures, the console automatically creates groups for you. A fixture type group is created which contains all fixtures of the same type (for example, All Robe Pointe). Another group is created each time you patch a quantity of fixtures (for example, 4 BB4.) This function can be turned off using Auto Groups in the User Settings.
  • "All" fixture type groups can't be deleted - when you press Delete the group will become unassigned and be moved to the Show Library. This is also the case if a group has been used in a pixel effect. Titan shows a warning message.
Fixture Order and Fixture Layout in groups​
Fixtures in a group are stored with a two-dimensional position layout which is used by Shapes and Pixel Mapper. Initially fixtures are arranged in a row in the order you selected them when you created the group, but you can edit this to reflect the actual physical location of fixtures. The horizontal (X) position of each fixture is used to create a Fixture Order which the console uses with Fan and Overlap.
You can edit fixture positions in the group either by Fixture Order or by the Group Layout editor, but remember that the fixture order is set by the x-position of the fixture so changing one will automatically change the other.
The Group Layout can also be used when creating Layout screens as described in the next section.
Fixture Order​
Fixture Order
To change the numerical fixture order:
  1. Press Group.
  2. Select the group you want to edit.
  3. Press Fixture Order.
The fixtures in the group will be shown numbered in the fixtures window.
Fixture Order
To change the order, select Auto Increment to On, then select the fixtures in the order you want. If you press a fixture twice, it will show an X indicating that it is not part of the sequence.
Group Layout​
Fixture Layout
To change the 2D fixture layout for the group:
  1. Press Group
  3. Press Edit Layout. The Group Layout Editor window will open.
Initially fixtures will be all in a row. You can reposition the fixtures anywhere on the screen by dragging them. Or press a fixture to select then use the wheels (Position X, Position Y, Angle) to move it around the grid or to rotate it. You can resize the grid by dragging the bottom or right sides.
Multi-celled fixtures appear showing all the cells but when moved or rotated, move as a block. Depending on the fixture personality, sometimes the cells may not match the actual physical layout of the cells on the fixture.
Group Layout Editor
  • The X-coordinate of the fixture layout is the same as the Fixture Order. Changing one will cause the other to change.
  • When setting the grid size, think about leaving space between fixtures to more accurately match the real world layout, and make sure you have enough cells in the grid for all the cells of the fixtures you need to fit in.
  • It is possible to accidentally overlay one fixture on another, making the bottom fixture hidden. To access overlaid fixtures, drag off the fixture which is hiding it, or select the hidden fixture and use the wheels to move it somewhere visible.
  • The Arrange Fixtures context button will automatically place the fixtures in a rectangular block, you specify the number of rows (Height) and columns (Width).
  • You can use the Fan button with the X / Y wheels to evenly spread fixtures in the layout.
  • To move or rotate fixtures, select and drag, or select and use the wheels. You can click on the "up" and "down" areas in the wheel display to nudge the values up and down - 1 grid square for position and 45 degrees for rotate. If you press the @ button for the wheel, a window opens allowing you to type in the values numerically.
  • If you select multiple fixtures, when you set Angle using Wheel C the fixtures themselves will rotate. If you want to rotate the whole fixture selection as a group, press the context button Wheels Rotate Individual Fixtures to change it to Wheels Rotate Selection.
  • Normally the fixture positions will snap to the grid squares, and Angle snaps to 45 degrees, however you can change to sub-pixel accuracy on the wheels by pressing the context button Wheels Move Full Pixel to change it to Wheels Move Sub Pixel.
  • To move individual cells of a fixture, select the fixture cells (see Fixtures with multiple cells) and record a group of the selected cells. Then by using the group in the fixture editor you can position the individual cells. This may be useful if the fixture personality does not have the cells positioned correctly, though it may be better to fix the personality or report a personality bug.
  • If you click the context menu button Position and Angle it will change to Scale which allows you to spread out or compress the cells in a multi-cell fixture. This is useful to get cells located correctly if you have some fixtures with large cell spacing and some with small spacing.
Position
Scale
You can temporarily randomize the fixture order when selecting fixtures using a group by holding down the group button and pressing Random Order which appears as a softkey option while the button is held.
