Patching fixtures
Press Patch, Dimmers or Fixtures.
For Fixtures, from the softkeys choose fixture manufacturer (type on keyboard to filter the list) then fixture type, then fixture mode.
Set DMX Line and Address. Console will automatically set these if you don't change them.
Press buttons in the Fixtures window to patch the fixtures (See Patching Fixtures or Dimmers).
To patch a number of dimmers or fixtures at once, draw a selection box over buttons on the screen. Or, set Quantity in the patch menu.
To change DMX address or line once patched, use Repatch Fixtures or the Patch View screen as described below.
To replace/exchange/morph fixtures with similar fixtures, patch new fixture onto same button(s) as old fixture and select Exchange Fixture (see Exchange Fixture). Titan will try to map similar attributes or you can do this yourself.
View fixture patch​
To see an overview screen of how the console is patched, press Open/View then Patch to open Patch View.
Setting fixture options​
Press Patch, Edit Fixtures, or use the Patch View screen.
