Set List Window
The Set List window is a handy way of linking playback pages to songs/events in your show which you can then easily step through. You can also make notes, handy for avoiding bits of paper lying around. You can have multiple set lists in a show.
Set Lists
To open the Set List window, double press Open/View then press Set List from the window select buttons which pop up. Or from the top level menu press Open Workspace Window then Set List.
The Set List feature works best if you arrange your playbacks to have a page of playbacks for each song in the show.
Set List Window
A set list is made up of tracks. When a track is added it automatically links to the current page. Pressing the Play button > to the left of the track name will automatically select the correct playback page (except on Pearl Expert, because the rollers cannot be moved automatically).
Creating a Set List​
To create a Set List, click the + button in the top right corner of the window. You can choose Empty, Pages, and Build:
  • Pages will automatically create a set list using the legends of your existing playback pages, one page per track.
  • Build allows you to select the pages in the order you want them.
  • Empty: your start with an empty list and can manually add tracks using the + button below the track list.
Configuring Tracks​
Enter notes by selecting a track and clicking the text entry button, bottom right, or the Edit Note context menu button.
  • You can temporarily remove a track from the set list using the Park Track context menu button.
  • If you prefer to operate by using the Page+/Page- buttons, you can change the function of these buttons to step through the tracks in the set list window, using the Page Mode context menu button. When Page Mode is set to Set List, the Page+/Page- buttons are reassigned to step through tracks in the Set List, and the playback pages will automatically change as programmed in the Set List. Set Page Mode to Normal to restore normal operation. (Not available on Pearl Expert).
  • You can copy, move and delete tracks using the appropriate function buttons on the console.
  • You can change the legend of the Set List or of individual tracks using the Set Legend option.
You can trigger macros and workspace shortcuts from tracks using the Workspace and Macro buttons in the bottom right hand corner of the window.
To add a workspace link to the current track, click Workspace, then either click a workspace shortcut or press the Record Workspace softkey to save the current workspace.
Macros can be added either to the whole Set List or just to the current track. Set List macros will fire every time a new track is selected, this is useful for setting the console to a preset state at the start of every song. Track macros will just fire for that individual track.
To view or edit the workspace links and macros, click the Workspace & Macros tab on the right hand half of the window. The window will then show a button for each programmed link.
Workspace & Macros
You can fire the macro or Workspace shortcut by clicking on the link button. Delete the button by pressing Delete then clicking the button, then press Remove.
Playback Control Macros​
Key Macros allow you to record a sequence of actions on the console then play them back (either instantaneously or as a timed sequence). This can be very useful for reducing a complex sequence of actions to a single button push.
Some special preset macros are available to help with controlling playbacks when used with a Set List.
MacroAction
Fire First PlaybackFires the first playback on the current page.
Fire First Playback Page 1Fires the first playback on page 1, regardless of current page.
Fire Playback 1Fires the playback with user number 1.
Kill First PlaybackKills the first playback on the current page.
Kill First Playback Page 1Kills the first playback on page 1, regardless of current page.
Kill Playback 1Kills the playback with user number 1.
Release First PlaybackReleases the first playback on the currently selected page.
Release First Playback Page 1Releases the first playback on page 1, regardless of current page.
Release Playback 1Releases the playback with user number 1.
Release MeReleases the associated playback (cue list).
Goto My Cue 1Go to cue 1 of the associated cue list.
