Loading and saving shows
You can save any number of different shows on a USB drive or the console's internal hard disk. The console will also autosave the show periodically.
Shows created on a Titan console can be loaded into any other model of Avolites Titan console.
You can load show files from an older version of Titan into a newer version (e.g. v16 show into v18 console).
Loading show files into an older version console is not supported and will not work correctly.
Although your show is safe on the hard disk, it's a good idea to also save it to a USB pen drive which you can take with you in case something bad happens to the console or if you want to transfer a show to a different console.
Saving the show​
You can save your show at any time either with its current name or with a new name. If you save your show with its current name, a new version of the show will be created. This allows you to go back to previous versions of your show if needed.
To save your current show:
  1. Press the Disk button.
  2. Press Save.
  3. If you have a USB drive connected, use the softkeys to select whether to save on Removable Disk or Internal hard drive.
  4. If this is a new show, enter a name for the show on the keyboard. If this is a new version of an existing show you can enter a tag to help identify the version, which will be shown on the Show Browser screen when you load shows.
  5. Press Enter or Save (or Overwrite if the show already exists). The show will be saved.
  6. Press Exit or OK to leave Disk mode.
  • To save the show under a different name, use the Save As softkey.
  • Pressing the Disk button twice will make the console save a Quicksave version of the file. A Quicksave is just a version of the show saved with the same filename.
  • A new version of the file will be saved even if you enter the same tag as previously used.
If you save to hard drive, shows are saved in the folder 'D:\Shows' (on Titan PC Suite (Titan Go / Simulator) the folder is 'Documents\Titan\Shows').
Loading a show​
The console will automatically reload the last show when it is turned on.
Show BrowserPress the Disk button then Load Show to load in a new show. The Show Browser window will appear.
On the top left you can select which drive is used, or show files on all drives. On the bottom left you can filter the list of shows to see all shows, or just manual saves, quick saves or autosave files. On the right you can see different versions of the showfile; this allows you to reload an earlier version if you need to.
You can also load shows from the softkeys:
  2. Press Load Show.
  3. If you have a USB drive connected, select which drive you want to load from.
  4. Available shows are listed on the softkeys; press the key to load the show (the F and G keys show more pages). If you type the first few letters of the show name on the touch keyboard, the list will only include shows starting with those letters, which can make it easier to locate the show you want.
  5. If there are multiple versions of the show stored on the disk, select the one you want.
  6. Press Load Show. The console will show a loading screen as the different elements of the show load.
  7. When the show has loaded the normal operating screen will reappear.
When loading a show you have the option to keep the existing DMX settings of the console, or to load the settings stored in the showfile. The DMX settings determine how the XLR sockets on the back of the console are used and how DMX is sent over the network using TitanNet.
Importing parts of other shows​
If you are doing a show which is similar to a previous one, you might want to import parts of the previous showfile, for example you might want the palettes for some Robe Robins from another show, but not the other fixtures. This is where the Import Show function comes in handy.
For Import Show to work, you need to map fixtures from your imported file to fixtures in the current show so that Titan knows where to import the programming to.
Fixture Mapping
You can then select items from the imported show and store them onto workspace or panel buttons in your current show.
Import
  2. Press Import Show (The plus button at the top right of the Show Library window also opens this menu).
  3. The Show Browser window opens. Select the show you want to import from and press Load Show.
  4. The Show Library window will now open. Your current show and the imported show will appear as buttons at the top of the show browser. You can import items from more than one show at once by repeating steps 1-3.
  5. Click on the Mapper tab, and select your imported show.
  6. Select a fixture in your imported show, then click the arrow beside the fixture it maps to in the current show. To remove a mapping, click the Clear Fixture Mapping context button.
    You can select multiple target fixtures by dragging a box over the fixtures, or click on the source fixture again and map to another target.
  7. When you have mapped all fixtures you want to import data from, click on the Show Library tab.
  8. Select the items you want to import (single or multiple). Use the buttons on the left to select Palettes, Groups etc.
  9. Select handle(s) where you want to store the imported items.
  10. When you have imported all the items you want, press Exit.
  • You can filter fixture types to make the mapping easier using the buttons on the left and right sides of the show browser.
  • You can directly import shows without using the Disk menu by clicking the Plus button at the top right of the Show Browser.
  • You can find more information about the Show Library here.
Autosave​
The console will automatically save your show to its internal hard disk when you shut it down. It will also autosave the show every 30 minutes in case the console loses power.
You can disable Autosave or alter the time between saves using option Auto Save on the Disk menu (press the Disk button). You can reload Autosave files using the Show Browser.
This option is included because Autosave used to make the console pause, however this is no longer the case and we recommend that you do not disable Autosave. If you lose power while programming Autosave will make your day a whole lot better.
Recover show​
If Titan shuts down improperly due to a crash or power failure, and when you restart it the most recent showfile can't be reloaded, a softkey option Recover Show will be displayed which will attempt to load the show from the temporary directory. You will also see options to start a new show or load a previous show.
Backing up existing show files to USB pen drive​
If you just want to save a copy of your current show, you can use the normal save function to save it to the USB drive instead of the hard drive.
To copy an existing show file on the hard disk to a USB drive, first ensure your current show is saved, then use the Disk functions to load the existing show from hard disk, then save it to the USB drive. Alternatively you can use the Folders command on the Tools menu.
Setting a show to load on start up​
Normally on start up the console will reload the show it was using when it was last shut down. In some situations (for unattended operation or for use with venue mode) you might want to always load a default/standard show on power up, in case someone has loaded a different show the night before. The Start Up Show function lets you do this.
  1. Load the show that you want to be the default Start Up Show.
  2. Press the Disk button.
  3. Press Next softkey until you see the Start Up Show option.
  4. Press Start Up Show softkey. This will show Unlocked if no Start Up Show is set.
  5. Press Create and Lock Show. The current show will now be loaded on power up and the option will show Start Up Show Locked.
  6. If a Start Up Show was already set/locked, you can Update Show to change the Start Up Show to be the currently loaded show or you can Unlock to disable the Start Up Show. option.
You can also configure playbacks to fire when the show is loaded, this lets you put the venue into a known state when the console powers on (for example if working lights are run from DMX or you want to startup with a basic lighting state on). See Run On Startup in the Cues chapter.
If this option is configured, unsaved changes will be lost when the console is shut down.
