Key Profiles
The console allows you to reconfigure how the front panel buttons work to suit your method of working. You can save your settings as a Key Profile. Different profiles can be selected for different users or to enhance the operation of the console for a particular use.
There are standard Key Profiles for Run mode, Takeover Run mode, Program mode, Theatre mode and Nightclub mode. These standard profiles cannot be edited, so you always know how they will behave. You can create your own editable profiles using one of the standard profiles as a starting point.
The current settings of the playback buttons are shown on the screen related to each playback fader.
Key Profiles on playback
Creating and editing key profiles​
Video covering Key Profiles
To create or edit a profile, switch to System mode then select Key Profiles. You can then use the Manage Profiles menu to View, Edit, Add, Delete or Rename profiles.
You can also create or edit key profiles in the Handle tab of Playback Options.
Key Profiles can also be viewed from the Show Library window as described in Show Library section.
When Adding a new profile, you can select an existing profile to copy settings from.
You can also edit Key Profiles from Program mode by holding Avo, then selecting Edit Current Key Profile. If the current key profile is one of the non-editable system ones, you are prompted to add a new profile or select an existing editable profile.
The current actions for the Black, Blue, Grey and Touch buttons are shown on the left side of the screen. Once you select a key type from the menu, the screen shows actions available for that type of button. Only the Sapphire Touch has black buttons.
Editing a Key Profile
Actions for Buttons​
The groups of keys you can set are as follows. The blue or grey fixture/palette buttons only exist on the Pearl Expert, on other consoles these settings will not do anything.
Fixtures​
The blue, grey or touch key can be allocated to Disabled,  Select, Flash, Swop, Latch.
The "Latch" function is equivalent to putting the fader to full for that fixture and touching again returns the fader to 0.
Groups​
The blue, grey or touch key can be allocated to Disabled,  Select Group, Flash Fixtures, Timed Flash, Flash Master, Timed Flash Master, Swop Fixtures.
You can select if the group function takes precedence over the flash function (if a handle has both group and flash functions) or vice versa.
Palettes​
Only effective on Pearl Expert.
The palette (grey) key can be allocated to Disabled or Select Palette. You can select if the palette function takes precedence over the flash function (if a handle has both palette and flash functions) or vice versa.
Cues​
The blue or grey key can be allocated to Disabled, Flash,  Swop, Latch, Preload, Go.
Chases​
The blue or grey key can be allocated to Disabled, Flash,  Swop, Latch, Go, Stop, Preload, Connect, Tap Tempo.
Cue Lists​
These affect playback of cue lists and can be assigned to the handle's buttons:
SettingAction
DisabledThe button will do nothing
FlashAll dimmer levels in the cue will flash to programmed level, when released the levels will return to previous level
Flash and GoAs Flash, but when button released the cue list will advance to the next cue
Timed FlashAs Flash, but fade in and out times will follow the cue times set
Timed Flash and GoAs Flash and Go, but cue list will advance on release
SwopAs Flash, but all other fixtures will black out
LatchAs Flash, but dimmers will remain active until button pressed again
GoCue list will advance to next cue using times
StopStops all fades in the cue list at their current point
PreloadLTP channels of non-illuminated fixtures will move to positions in next cue
ConnectConnects this cue list to controls (same as pressing Connect then select button of cue list)
Tap TempoSet speed parameter by tapping the button
Next Cue -Press repeatedly to select the next cue to be output, going backwards
Next Cue +Press repeatedly to select next cue to output, going forwards
Review Live CueReplays the current cue using fade times
Cut Next Cue to LiveOutput the cue as selected using above
Snap BackCue list will snap back to previous cue without times
Go BackCue list will go back to previous cue using fade times
ReleaseRelease the playback using programmed release time
Select IfPress to select all fixtures used in the current cue
Macros​
Can be set to Select or Prefer Macro (the Macro function will take precedence over other functions stored on the button).
Options​
Allows you to disable the quick record function (double tap on empty handles).
Masters​
This is divided into Standard Masters and Scene Master.
For Standard Masters the options are Disabled, Selection, Flash, Latch, Tap Tempo, Nudge Up, Nudge Down, Release, Reset Multiplier, Multiplier x2,  Freeze, Connect.
These last options are for rate and BPM masters, see the BPM Master Options. Freeze can be useful to temporarily pause shapes or chases, or does a blackout if used with an intensity master.
For Scene Master the options are Disabled, Exit scene mode, Enter scene mode, Commit changes, Commit changes and exit scene mode, Enter or Exit scene mode, Enter or commit scene mode.
Selecting a Key Profile​
To quickly select a Key Profile, hold the Avo Shift button and press
Select Key Profile.
Individual Key Profiles for playbacks​
Each playback can have an individual Key Profile allocated to it. This allows you to customise the panel button functions differently for each playback. The Key Profile for the playback is selected using the
Handles option on Playback Options. If the playback Key Profile is set to Global, the default global profile for Cue / Chase / Cue List is used.
