Creating Reports
When preparing a show it is often useful to create a report of how the show is patched or programmed on the console, for example to give to a crew when pre-rigging fixtures, or just for your records.
Reports can be created in HTML, PDF, CSV or XML formats for the following:
Fixtures
Memory (Cues)
Chases
Cue Lists
Palettes
Groups
To generate reports:
Press the Disk button.
Press Reports.
Select the item(s) you want to include in the report
Select the format in which you want to output the report
Select the drive where you want to save the report
Reports are stored in the following folders:
PC suite (Editor/simulator, Titan Mobile., Titan Go):
Documents/Titan/Reports
All other consoles: D:/Data/Reports
When the report is complete, Titan will open the folder where the report is stored so you can see where it went.
