TNP Console Mode
TNP console mode allows you to use a TNP to run an unattended show, or to act as an emergency backup. You can create a show on a full console then load it into the TNP for operation, or you can connect a console in multi-user mode to create programming on the TNP itself.
Running Playbacks​
Use the View command (see next section) to select Playbacks Grid mode.
Playback View on TNP
You can then run playbacks from the standard Titan playbacks window by touching the buttons.
Setting the View​
In Console mode, the Home screen can be set using the View button to display either Network Adapters (like in slave mode), Playbacks Grid or Session View.
TNP View Screen
Session view shows how the TNP unit is connected to other Titan devices on the network.
TNP Sessions View Screem
Locking the panel​
The selected view will also be shown when the console is locked using the Lock button. If the playbacks screen is shown, the only action available is to fire and kill the playbacks on the screen. Touch the Show Keypad button to display the numeric keypad for unlocking.
TNP Locked Playback View Screen
Loading and saving shows, and other Setup​
Setup mode allows you to load and save Titan shows. You can also change Network Settings, Node Settings and set Monitor mode (see Slave mode above for details).
TNP Setup Screen
Load show presents the standard Titan loading screen.
TNP Setup/Load Show Screen
Save Show allows you to save a show which you have modified on the TNP using a remote console.
TNP Setup/Save Show Screen
