Creating Reports
When preparing a show it is often useful to create a report of how the show is patched or programmed on the console, for example to give to a crew when pre-rigging fixtures, or just for your records.
Exported Report
Reports can be created in HTML, PDF, CSV or XML formats for the following:
  • Fixtures
  • Memory (Cues)
  • Chases
  • Cue Lists
  • Palettes
  • Groups
To generate reports:
  1. Press the Disk button.
  2. Press Reports.
  3. Select the item(s) you want to include in the report
  4. Select the format in which you want to output the report
  5. Select the drive where you want to save the report
Reports are stored in the following folders:
  • PC suite (Titan Go, Titan Simulator): Documents/Titan/Reports
  • All other consoles: D:/Data/Reports
When the report is complete, Titan will open the folder where the report is stored so you can see where it went.
