Capture Show Files
The Capture stage is automatically saved within the Titan showfile. The Capture stage can also be exported and imported separately from the Titan show. This allows standard stages or rigs to be transferred between Titan shows, or to be loaded into the full version of Capture for further editing.
Select the Show tab in the Capture Settings window to export and import shows.
Exporting Shows​
Exported Capture shows can be loaded into other Titan shows or into the full version of Capture for producing documentation.
Importing Shows​
Shows can be imported from the full version of Capture, this can be useful to import existing stage structures or rigging designs.
The internal Capture engine uses the Capture 2018 version (prior to Titan v12, Capture Atlas was used). You will not be able to import files from newer versions of Capture - use the "Export for Capture 2018" function in the File menu of the full version of Capture to save the file as a version which can then be imported.
You can import fixtures from full Capture but you need to ensure that fixtures are correctly patched in Capture to match the patch on the console. There is no way to edit an externally created Capture patch on the console.
Some fixture types and other Capture elements may not work when you import a show that has been created in full Capture. We recommend you use the auto-patch function to allow the console to patch the fixtures into Capture.
Clearing the Capture Show​
The Wipe button at the bottom of the Show tab will clear the current Capture show.
If you need to reload patched fixtures from your Titan show into Capture, select the Edit Fixtures Update Personality option on the Patch menu. This will place all patched fixtures from the Titan show into the visualiser.
