Cue List Playback
Running a Cue List​
Raise the fader of the cue list and press the Go button to run the first cue. The wheel display section of the screen shows the cue list status; the current cue is highlighted and the next cue has a grey box around it (On Diamond 9 the cue list status is shown at the bottom of the Editor screen).
Connected Cue List view
Also the playback legend display for the cue list shows information about the cue list. The current cue is shown at the top in light blue, with the next cue below in dark blue. Fade progress of the cue is shown in a bar graph in the light blue bar. Below this the times for the next cue are shown - in time with up arrow and out time with down arrow, d for delay and f for fade. If the cue list is set to manual crossfade a red 'M' is shown.
Playback handle of running cue list
You can also open the Playback View window to show more details of the cue list by clicking the Cue List legend area or press Open/View then the Select button of the playback. This shows all the timings, links and tracking status and is very useful when running a theatre show on a cue list.
The option Auto View On Connect in the Wheels tab of User Settings) if enabled will automatically open the relevant Playback View window when you fire a cue list.
Playback View of Cue List with cue fade in progress
When times are in progress on a cue, green progress bars are shown in the Playback View window - the left hand column shows overall progress, and each timing section shows its own progress.
The Playback View will autoscroll to keep the active cue on-screen. You can change the way the autoscroll works using the view options (click the Cog button at the top of the window).
  • The HTP levels of cues in the cue list are mastered by the fader level.
  • You can pause a fade by pressing the Stop button above Go. Press Go again to resume the fade.
  • You can skip to any cue in the cue list by selecting a "next" cue using Wheel A, or using the left/right arrow keys. When you press Go, the cue list will run that cue next. If you decide you don't want to skip, you can reset the cue list (so the next cue will be the cue after the current cue) by pressing the Prev Cue and Next Cue buttons together.
  • You can go back to the previous cue following fade times by pressing Stop while the cue list is paused.
  • You can snap back to the previous cue by pressing the Snap Back button (not on all consoles).
  • Turning on the Snap button will cause the Prev/Next buttons to snap immediately to the cue rather than going to the previous/next cue using the programmed times. There is also an option Chase snap in the General tab of User Settings which enables this mode on consoles which don't have the button.
  • You can jump directly to a cue by pressing Connect/Cue, then typing in the desired cue number, then pressing Enter or softkey A.
    Alternatively at the top level menu you can type the cue number then press Connect/Cue. (This button may be labelled Connect or Cue depending on the console).
  • You can use Key Profiles to set the buttons of the playback to have various functions including Go, Stop, Connect, Next Cue, Prev Cue, Cut Next Cue To Live, and Snap Back, see Key Profiles.
  • When you lower the fader for a cue list, the HTP channels will fade out, but the cue list will remain active. The section below details how to kill the cue list.
  • You can use timecode to play back a cue list automatically. See section Cue List Timing.
  • You can change the time for the next cue by entering the time on the keypad then pressing Go. You can jump to another cue and set a different time by typing the cue number then press Connect/Cue, then type the time and press Go.
Killing a Cue List​
Once a cue list is fired, it remains active until you kill it. You do this by holding down the Avo button and pressing the Select button of the cue list's handle.
You can change this in the playback Options to make the cue list automatically clear when the fader reaches zero (press Options or the menu button Options at the program menu, then press the Select button of the cue list, then select Fader Fader Mode Intensity Kill At 0.
You can also use Key Profiles to configure one of the handle buttons to release the cue list.
While the cue list remains active, any shapes/effects stored in the current cue will run even if the fader is at zero. If you are working with a cue list and have unexplained shapes occurring, check all cue lists have been killed.
Tracking​
Tracking in Cuelists
By default, cue lists run in tracking mode. Only changes in attributes are stored, everything else just continues at the level it was previously set to. Tracking mode is usually used for theatrical performances because it makes editing much easier; if you need to adjust a dimmer level at the start of a scene, you don't have to go through and change the level on every cue for that scene, the change just tracks through the other cues until a new level is stored.
You can enable or disable Tracking mode globally for the whole cue list, or each cue can have Tracking mode set individually from the Playback View window (or Options, Cue Options).
Settings are:
SettingAction
Global (default)Obeys the global setting for the cue list.
TrackThe cue will track
BlockThe cue will not take tracking states from previous cues. All subsequent cues will track from the Block cue.
Solo Excluding ShapesNo states are tracked into or out of the cue, but shapes will track into the cue, except for dimmer shapes which will not track. This lets you have a cue that solos all levels but allows non-dimmer shapes to continue.
Cue OnlyChanges in this cue will not track to subsequent cues. Tracked values from previous cues will be restored in subsequent cues.
SoloNo states are tracked into or out of a solo cue. States from previous cues will track to subsequent cues but will not appear in the solo cue.
Block ShapesAny tracked shapes will stop from this cue. Other attributes will continue to be tracked. This lets you create a point where you can guarantee all shapes will stop.
You can view and edit how levels track between cues using the Tracking View.
Move In Dark (MID) Functions​
When using moving lights in theatre, often you would like them to be positioned ready for the next cue so that you do not see them moving. The Move In Dark function does this by automatically positioning the fixture for the next cue when it is not lit.
Move In Dark options can be set either for the whole cue list or for individual cues.
Options for the whole cue list are set by pressing Options (or the Options softkey on the top level menu) then the select button for the cue list, then Playback.
SettingAction
DisabledPrevents Move In Dark functions for all cues in the cue list regardless of the individual cue settings
EarlyWill attempt to position a fixture as soon as possible unless overridden in an individual cue
LateWill position the fixture as late as possible
Off (default)Turns off Move In Dark unless enabled in individual cues
For individual cues the options are set using the Playback Window.
SettingAction
Global (default)Uses the cue list's global setting
Cue NumberSpecifies a cue where you would like the move to occur
Cue OffsetSpecifies a preferred number of cues in advance
DisabledPrevents Move In Dark for this cue
EarlyWill move as early as possible
LateWill move as late as possible
Move In Dark delay and Move In Dark fade times can be set for the whole cue list or for each cue using the Set Times menu. Each cue also has a Move In Dark Inhibit option which prevents any movements during that cue (useful if you need to prevent fixture noise at a particular point).
If the fixture has its intensity above zero or Move In Dark is inhibited when the Move In Dark is supposed to occur, the console will attempt the movement in the nearest suitable cue instead.
Key Profile Options for Cue Lists​
Using Key Profiles, you can assign different functions to the buttons of the playback handle. (The Sapphire Touch also has an additional black button). If the cue list is stored on a touch button you can assign a function to that. See Key Profiles for a full list of functions.
