Cue List Timing
Time and Fade Options for Cue Lists​
The easiest way to set timing options for cues in cue lists is using the Playback View grid display (press Open/View then the Select button of the playback). Tap on the value you want to change, or drag to select multiple values to change. You can also select the active cue using Wheel A or by pressing Select Cue Number softkey in the Edit Times menu for the cue list. You can select a range of values using Wheel B.
Once you have selected values to change, the softkeys show you what you are setting.
Cue List Timings
For each cue you can independently set fade times for fixtures which are fading in (to a higher dimmer level) and fixtures which are fading out/down (to a lower dimmer level). The fade-out times are normally set to be "As In", so the "Fade In" time will be used for all fixtures.
LTP channels (all attributes other than brightness) will fade using the "Fade In" time.
  • Fade In sets the fade time of fixtures which are fading to a higher dimmer level than in the previous cue, and also fade time of LTP channels. If the Fade/Delay Out times are set to "As In" (default) then this will also set the fade time of fixtures which are fading to a lower dimmer level. Type a time in seconds and press Enter.
  • Delay In sets the delay time between pressing Go (or other cue trigger) and the start of the fade-in.
  • Fade Out sets the fade time of fixtures which are fading out/down to a lower dimmer level than in the previous cue. It is set by default to be "As In", the same as the fade in time. To go back to "As In", delete the time and leave the box blank.
  • Delay Out sets the delay time between pressing Go (or other cue trigger) and the start of the fade-out. It is set by default to be "As In", the same as the delay in time. To go back to "As In", delete the time and leave the box blank.
Cues in cue lists may be linked together, allowing you to build up complex self-timed sequences. The link options are set using the softkeys and are:
Link OptionAction
Link Wait For GoThe cue waits for the Go button to be pressed then fires immediately. Link Offset is disabled.
Link After Previous CueThe cue fires when the previous cue has finished its delay in and fade in times. A Link Offset can be set to add a delay between the previous cue finishing and this cue firing. The offset can be given as a time in seconds, or as a percentage of the fade time of the previous cue.
Link With Previous CueThe cue fires at the same time as the previous cue fires. A Link Offset can be set to add a delay between the previous cue firing and this cue firing, set either in seconds or as a percentage of the fade time of the previous cue.
Cue List Linking Diagram
These options allow you to create complex self timed sequences by building up simple steps. For example if you wanted the following effect:
  • Go is pressed, fixture one starts fading up over 20s
  • After 10s fixture two fades up over 15s
  • Both lights stay on for 5s
  • Both lights go off in 3s
You could program
  • Cue 1 - Fixture 1 @ 100%, Fade In 20s, Link Wait For Go
  • Cue 2 - Fixture 2 @ 100%, Fade In 15s, Link With Previous, Link Offset 10s
  • Cue 3 - Fixture 1 AND 2 @ 0%, Fade Out 3s, Link After Previous, Link Offset 5s
To obtain the effect which was called "cue overlap" in previous versions of software, use Link With Previous Cue and set a percentage Link Offset time. Link Offset of 100% is equivalent to Cue Overlap of 0% and vice versa.
Individual Attribute Fade Times​
You can set individual fade times for each IPCGBES attribute group. You can also select which fixtures this is applied to. For example you can make the position change take 2 seconds, but the colour change take 10 seconds.
Additionally you can set individual times for each attribute so you could make the pan fade over a different time to the tilt.
To set times for an attribute group, first select the Edit Times menu and go to the cue you want to set as described above, then press Next to go to the second page of options.
  1. Press Attribute Group Times.
  2. All fixtures in the cue will be selected. If you don't want to change the times for any fixtures, deselect them now. You can press the ALL button (below Next Time) to select all fixtures in the cue or Avo + ALL to deselect all fixtures.
  3. Press the softkey for the attribute group you want to change.
  4. Press Delay to set the delay time, or press Fade to set the fade time. If a time is set you can return to the Global time setting by deleting the time using the Back button or by pressing Use Global.
You can use Individual Attributes to set times for one attribute within the group, for example just Pan from within the Position group. You can also use the Cue View window to set times for individual attributes.
Fixture Overlap​
For each cue you can set a fixture overlap, which creates an effect where the fixtures in the cue are changed in sequence rather than all at the same time. This is described in more detail in Cue Timing.
Running a Cue List to Timecode​
Recording Timecode
The console can run a cue list automatically to a timecode. This is very useful for complex performances which must be exactly the same time every time, or for unattended operation. Each step in the cue list is assigned a time at which it will run.
See also Timelines which offer a more streamlined way of producing a show to timecode.
The console can have up to 4 separate timecode sources. For each, the timecode can be read from the system clock, from an internal timecode source, from MIDI, SMPTE or from the Winamp player which is installed on the console. Internal timecode is useful for programming a sequence which will later be triggered by an external timecode source.
For Winamp timecode, use WAV tracks rather than MP3 tracks as Winamp sometimes generates incorrect or offset timecode when playing MP3. If you pre-program a show using Winamp MP3 then switch to external timecode for the show, your trigger points may end up out of place.
  1. Connect the cue list for which you want to set timecode.
  2. Press Timecode on the top-level menu.
  3. Press softkey A to select Timecode 1-4, and softkey B to select the desired timecode source.
  4. Press Record.
  5. Start the timecode source. If using internal timecode, press Play to start it.
  6. Press the red Go button to step each cue at the time you wish the cue to start.
  7. Press Record when you have finished.
To play back a timecoded cue list, press Connected Cue Lists on the Timecode menu and select the cue list which is to be played. Then press Timer Disabled/Enabled to enable the timecode input. Note that the Timer Disabled/Enabled toggle affects all four timecode streams as it is a general timecode switch. If you just want to disable a specific timecode stream then set its source to No Timecode at Step 3.
When you start the timecode source (or press Play if using internal timecode), each cue will fire as the timecode matches its programmed time.
In order to edit a cue's timecode, select the cue's timecode cell in Playback View and enter the correct time, or - using the menu buttons - press Edit Times, enter the cue number, toggle to the 3rd page of this menu with Next, click Timecode = and enter the new timestamp.
Playback View Window showing timecoded cues
While editing a time you can also use Wheel B to select multiple cues, and use the softkey options to enter a value to change the time of all the cues: Timecode = sets the timecode directly while a value set with Offset = can be used in Add + or Subtract - , to shift all selected timestamps by this timespan.
You can open a timecode display window for each of the four possible sources to show you the incoming timecode - double press Open/View then press Timecode x (where x is 1 to 4) from the workspace select buttons.
Timecode 1 Workspace Window
