Version: 1.3
Synergy Settings
Prism includes Synergy compatibility with Avolites Titan, providing easier setup as well as advanced features such as previewing of Prism within Titan, using the output from Prism within Titan's Pixelmapper and allowing media transfer directly from the console to Prism.
More information on how to setup a Synergy connection can be found on this guide. Settings Synergy
Feature
Description
Titan Media Node VersionList of available Titan Media Node. The version in use must match the Titan version.
If a mismatch is identified within Titan's Synergy Settings, a different version can be selected via this dropdown.
PortApecifies which port is used to allow Prism and Titan to communicate.
Enable SynergyThis toggle enable/disable Synergy connection between Prism and the controlling device.
Connection StatusIndicates the current status of the Synergy connection between Prism and Titan.
Default Upload FolderThis path is the default storage location used by all media transfered to Prism from Titan via a Synergy connection.
By pressing the Change Folder button it is possible to update the default destination folder that will be displayed in the box.
Auto TranscodeThis toggle will enable/disable the automatic conversion of any files transferred to Prism via Synergy without the need for user input.
Show/Hide Point OverlayThis toggle will enable/disable the point overlay visual feedback.
When adjusting the Group Layout of fixtures within Titan, this tool can be used to ensure precise alignment of the fixtures within the area of the media surface.
Automatic NDI PreviewsThis toggle will enable/disable surfaces and layers previews which can be displayed within Titan's Media Viewer through NDI.
