Skip to main content
Version: 2.1
General Settings
The General Settings page provides global configuration options for Prism Player,
Settings General
There are four sections:
  • Application - Controls settings related to the application’s user interface (UI).
  • Graphics - Controls settings for the application’s graphics performance and quality.
  • Audio - Controls settings for the application’s audio output.
  • Cache - Controls settings for the application’s caching system.
Application​
ItemDescription
Keep Server Running On CloseChoose whether the application continues running after closing the UI.
When enabled, the application stays active in the system tray and continues assigned tasks even after the UI is closed.
When disabled, closing the UI will fully exit the application regardless of its current state.
Disable UI NotificationsToggle UI notifications on or off. When enabled, messages from the application appear at the top of the UI.
UI WarningsResets the status of UI warnings. For example, if a "Render Warning" popup is disabled by selecting "Don't show this message again," pressing this button will re-enable that warning so it appears again when relevant.
Graphics​
ItemDescription
Graphics CardList of available GPUs on the system. The selected device will be used by the application to output video frames.
Audio​
ItemDescription
Audio Output DeviceList of available audio output devices on the system. The selected device will be used by the application to output master audio.
Cache​
ItemDescription
Clear CacheClears bank elements informations and thumbnails, resets Inputs settings and clears Undo/Redo history.
